carte station de base AM220ac - connection cable guide
guyc
Message par guyc »
I was trying to connect the guide wire on the base station of the 220ac. Unfortunately there are only 2 connection for the boundery wire. I check the internal wiring of the base station and could not find any unused wire. This is different with the spare part 544.98.38.01 I could find in the spare part list for a AM220ac.
On the electronic board of the base station there is a 8 pins connector, but only 6 pins are used (2 wires for the led, 2 wires 26 Vac, 2 wires for the boundary wires.)
Has someone the pin connections of this 8 pins connector ? Because I suppose the 2 unused pins are for the connection of guide1 and guide2.
Many thanks
AM 220ac
Malines
guyc
Message par guyc »
AM 220ac
Malines
guyc
Message par guyc »
It's the yellow wire on the pictures in this topic that is missing
http://automower-fans.les-forums.com/topic/3914/panne-station-de-charge-qui-clignote/
The pictures are very clear, except where the yellow wire is connected to the board
AM 220ac
Malines
guyc
Message par guyc »
Specifications automower :
AM :
Enland DL56UP
year :2007
Product No : 9650894-01
Software : AM 220AC CD
version : 2.80 B:33 U:00
oct. 20, 2010
Loading station : base plate replaced by newer version with circuit board 544 45 41-05
AM 220ac
Malines
guyc
Message par guyc »
Problem solved.
guide 1 can be connect on the 8 pin connector but also on the pin next to this connector.
When interested, I made a small tutorial from the modification
AM 220ac
Malines
