carte station de base AM220ac - connection cable guide
Publié : sam. mai 05, 2018 1:32 am
I was trying to connect the guide wire on the base station of the 220ac. Unfortunately there are only 2 connection for the boundery wire. I check the internal wiring of the base station and could not find any unused wire. This is different with the spare part 544.98.38.01 I could find in the spare part list for a AM220ac.
On the electronic board of the base station there is a 8 pins connector, but only 6 pins are used (2 wires for the led, 2 wires 26 Vac, 2 wires for the boundary wires.)
Has someone the pin connections of this 8 pins connector ? Because I suppose the 2 unused pins are for the connection of guide1 and guide2.
Many thanks
Many thanks
