High Resistance in Boundary Wire
Publié : mar. mai 19, 2020 11:21 pm
Hello All! I found this site after doing a Google search related to my problem. While I studied French in high school, fortunately, Google Chrome helps with the translation (otherwise I'd be in trouble).
Anyway....
I've had my Automower (model 315x) since early February--fresh installation made then of the boundary wire and guide wires (buried with a machine about 2" deep).
A few weeks ago, I had some grass sod installed. During the preparation and yard tilling, the landscaper pulled up the boundary wire in two locations. I repaired the breaks with no problems. All my previous repairs (twice now with sidewalk edger) have been made with twisting the wires, soldering and insulating tape wrapped around the soldered connection.
Unfortunately, after the repairs were made, I still have a flashing blue light (about 2 second intervals) on the mower base station indicating a broken boundary wire. I swapped the guide wire around (my model only has one guide wire) with the boundary wire connections and was able to determine which segment of my boundary wire has a problem--this section is about 400 feet long by my estimate. The good boundary wire segment is about 1050 feet. My guide wire is about 430 feet.
I have a resistance of 937ohms across the boundary wires. Since I do have "some" continuity, the toner and AM radio methods have proven fruitless to find my problem since I don't have a total break in the wire.
Resistance across the guide wire and good boundary segment is 8 ohms--so that looks good to me.
I read in a post on this site back from 2016, that some people use the HV-output of an electric sheep fence to help break the high resistance connection and make a full break that can then be tracked down.
Can anyone share anymore details regarding the electric fence approach? I have an electric fence module used on a friend's farm to try out. Do I connect one end of the boundary wire to the HV-output and the other boundary wire end to the ground output? Assuming the fence option doesn't work, can anyone share what other approach I should take to solve my problem?
Thank you in advance to the community and any assistance that can be offered!
-AUEngineer
Mobile, Alabama, USA
Anyway....
-AUEngineer
