PCB Stencil China Manufacturing
Publié : sam. juin 29, 2019 7:33 am
par jhypcb
[a https://www.pcbjhy.com/pcb-stencil/]PCB Stencil China Manufacturer[/a] - JingHongYi PCB (HK) Co., Limited
PCB Stencil, SMT Stencil, SMD Stencil, Laser Stencil
we are specialized manufacturers from China, PCB Stencil, SMT Stencil suppliers/factory, wholesale high-quality products of SMD Stencil R & D and manufacturing, we have the perfect after-sales service and technical support. Look forward to your cooperation!
Prototype PCB SMT Stencils
https://www.pcbjhy.com/pcb-stencil/56714708.html
Stainless Steel SMT Stencil
https://www.pcbjhy.com/pcb-stencil/56714698.html
Laser Cut SMT Stencils
https://www.pcbjhy.com/pcb-stencil/56714705.html
Electroformed PCB SMT Stencils
https://www.pcbjhy.com/pcb-stencil/56714702.html
Frameless PCB SMT Stencils
https://www.pcbjhy.com/pcb-stencil/56714695.html
Framed SMT PCB Stencils
https://www.pcbjhy.com/pcb-stencil/56714700.html
Apart from all types of Printed Circuit Boards (PCBs) such as Prototype PCB, Aluminum PCB , HDI PCB , Flexible PCB , Rigid Flex PCB, Thick Copper PCB, High TG PCB , JHYPCB also manufactures solder paste stencils to meet Surface Mount Technology (SMT) requirements.
PCB Stencils, also called SMT stencils, SMD stencil, play a key role in transferring accurate amount of solder paste to correct positions on bare circuit boards ready for assembly. In other words, stencils can fast and efficiently ensure the most accurate solder paste amount and optimal electrical connection. With solder stencils, it is possible to use metal squeegee blades to apply solder paste easily over the openings on PCBs and make stencil to be well aligned with the surface of the advanced circuit board.
All of our SMT Stencils stencils are 100% laser-cut type 304 full-hard stainless steel, ensuring the finest quality finish on the market today. We use a .001" laser beam with 98% overlap creating an extremely smooth hole that provides the best paste release. Most stencil fabricators use a .003" laser leaving mouse bites on the aperture edge. You can choose a PCB Prototype stencil, a frameless foil stencil, or a rigid permanently mounted stencil. Both the frameless and framed stencils come in various sizes to accommodate your printer and stencil requirements.
