Hi!
Sorry for writing in english, but here is my problem.
My Mower is a Automower 220AC 2008
With Dunkermotoren wheel motors.
When i try to start automower on the lawn it will only reverse until it drives over the boundary line and gives me a fault code "outside working area"
When i try to start it normal from the docking station it wil try to drive forward out from docking station and get stuck.
If i run a wheel motor test, one motor will run forward and one in reverse, the same motor will run in reverse, connected to right or left side.
this would indicate a problem with the wheel motor which is running in reverse?
But i cant find anything wrong with the wheel motor..
they both measure the same on all connections, i had a scope on the output terminals from hall sensors, they appered similiar on both motors.
Could it still be a faulty motor?
Automower 220ac Wheel motor problem or pcb?
Re: Automower 220ac Wheel motor problem or pcb?
Did your mower work correctly previously? What happened then?
It seems, you have a wrong board version, or a wrong program on the board, but it does not happen by chance
Regards
Regards
It did work previously.
Had a problem last season with a broken resistor which gave me fault codes "motor blocked."
Replaced that and testet this season.
Did some testing:
wheel motor test.
Motor 1
Connected to left side wires, motor spins clockwise
Connected to right side wires, motor spins counterclockwise.
Motor 2
Connected to left side wires motor spins counterclockwise
Connected to right side wires, motor spins clockwise
It indicates that there is something wrong with one of the motors, but i cannot find anything wrong
i made a test setup for hall sensors with led diodes. both motors appear similar.
both motors measure the same resistance on windings.
am i missing something?
Did some testing:
wheel motor test.
Motor 1
Motor 2
There's a problem with one of the motors, indeed. Hall sensor probably
My bet on the motor aswell, but i am getting crazy not finding the root cause...
Here is a video how i test the hall sensors. Both motors similar.
Looks ok to me.
https://youtube.com/shorts/y4VSh7TdMMA?feature=share
Looks ok to me.
If you dismantle the motor, you could check if the sensors / magnets are in the correct place.
Dismanteled motor. everything looks ok.
i have bought a new\used motor. will test when it arrives.
I will try to mount new hall sensors on my other motor, but i am having trouble identifying the hall sensors. any tips?
- hall.jpg (26.55 Kio) Consulté 835 fois
A little update:
Got a new wheel motor and now it works again
