Robomow RS
Pizza_m79
Robomow RS
Message par Pizza_m79 »
Hello
Encountered a new problem today. When pressing GO for cutting or going home it starts rotating on the same place. Will not go forward or backward just stays in same place doing 360dgr. When running test from service menu wheels spins same direction but when should cut it goes in opposite direction. Any ideas?
regards Matias
sittingbull
Robomow RS
Message par sittingbull »
hello
try to reset the cardboard (in the service menu)
43 AUVERGNE
Robomow RS630
mis en service le 12.07.2013
logiciel V2.12
utilisation 3387 h
tontes : 2 zones jour
H de coupe 50
abri porte basculante
Pizza_m79
Robomow RS
Tried that but still the same _o_
sittingbull
Robomow RS
Hello
beware, the reset output of the cardboard is very special since the robot is found in factory configuration as the day you unpacked ... which requires reprogramming completely ......
43 AUVERGNE
Robomow RS630
logiciel V2.12
utilisation 3387 h
H de coupe 50
