Hello from Scotland,
This forum looks very helpful.
I have a Husky 420 and I am going to put new cable around my garden as I have done some work. It will be easier to re lay new cable.
Can I use 1.5mm electric fence wire? I will need to use about 350m or so.
There are many types of electric fence cable, which should I use? I have looked at bare stranded galvanised, aluminium and stainless poly wire but I don't know which I need.
Can anyone offer advice? Many thanks in advance.
1.5mm Cable?
1.5mm Cable?
Husqvarna 420
Orkney Islands
Scotland
Orkney Islands
Scotland
1.5mm Cable?
Usually, we use 1.5 mm2 rigid copper wire. You will find it under reference :HO7VU
Automower 450x
Main : 10.19.00
Mise en service : 05/08/2018
Nogent sur Oise - France
1829 m2
Main : 10.19.00
1829 m2
1.5mm Cable?
@orkenny :
Where are you localised in Scotland ? (no need to be precise : for your signature + personal curiosity)
The 420x doesn't exist : 420 or 420 with Connect kit ?
@Cheminvert :
05/08/2018 ou plutôt 08/05/2018, précision de quelques mois pour la garantie, en espérant n'avoir pas à la solliciter.
@Cheminvert :
1.5mm Cable?
Merci Keops62 pour votre vigilance mais le 05 Aout c'est bien la date de mise en service. Encore quelques travaux à effectuer.
Automower 450x
Main : 10.19.00
1829 m2
Main : 10.19.00
1829 m2
1.5mm Cable?
I have found 1.6mm galvanised steel wire for sale, would that work? If it is galvanised I wonder if it would be good for underground?
Husqvarna 420
Orkney Islands
Scotland
Orkney Islands
Scotland
1.5mm Cable?
Hi orkenny !
Galvanised steel wire is not suitable. That wire is not isolated.
Electric fence cable is not suitable either: that cable is not isolated (otherwise animals would not be shocked by ellectrical pulses) and its metallic part is too thin (electrical pulses of electric fence has high voltage, but extremely low intensity and energy; otherwise it would hurt animals and people).
You need an isolated cupper wire as used for house electrical installation. On this forum we recommand rigid wire (i.e. one single thread of cupper) rather than flexible wire (i.e. multiple threads of cupper), because it is more resistant if, by accident, isolation is damaged. Wire cross section must be approximatively 1.5 mm2 . [a https://www.amazon.co.uk/Single-Conduit-Cable-6491X-Yellow/dp/B01N4RD86Y/ref=sr_1_20_m?s=diy&ie=UTF8&qid=1532127463&sr=1-20&keywords=Ali%27s%2BDIY&th=1]Example of suitable wire.[/a]
1.5mm Cable?
This is what you need:
https://www.amazon.co.uk/CoFan-51002554-Cable-1-5-mm%C2%B2-Black/dp/B00L1AXC7Q/ref=sr_1_5?ie=UTF8&qid=1532176713&sr=8-5&keywords=CABLE-ROLL-H07+1.5
